Cerwin Vega EXL 200.2, Hifonics Warrior,Cap,Gehäuse
Heady87
#1 erstellt: 05. Okt 2008, 19:39
Artikel:Cerwin Vega EXL 200.2
Preis:80€
Standort:96049
Zustand:kratzer aber sonst guter Zustand
Artikelbeschreibung:
* Full Frequency response with low distortion and exceptional signal to noise performance.
* Advanced circuit design that features bridgeable and mixed mode operation for use with various systems, including those with satellite speakers and / or subwoofers.
* Independent front and rear variable high-pass / low-pass/ flat electronic crossover with a 12dB per octave slope and full adjustable range (from 55Hz to 5.5kHz) to aid in audio system design.
* Continuously variable bass boost circuit to reinforce low frequency signals that may be lost due to subwoofer box design.
* Adjustable input level controls with ground loop isolation accepting a wide range of input signals.
* Remote turn-on with “soft start” muting to prevent turn on or turn off "Thump"
* Pulse-width modulated MOSFET power supply with low RFI and protection circuits for overheating and speaker shorts.
* 2-ohm-load capability to drive a variety of speaker systems
* .Nickel input / output connectors and an external automotive type fuse
* Aluminum heat sink for efficient heat dissipation
* Low profile, compact size for space limited installations.
* 2 x 100 watts into 2 ohms @ less then 0.1% THD
* 2 x 75 watts into 4 ohms @ less then 0.1% THD
* Vega Bass! Boost Control
* High Current MOSFET
* power supply
* Audiophile Class A/B
* Bipolar Output Stage
* Durable Mil Spec
* Glass Epoxy pcb
* Audiophile Grade Audio Components in Signal Path
* Variable 12dB/oct Highpass/Lowpass Crossover
http://img100.imageshack.us/my.php?image=50620301yh0.jpg
http://img100.imageshack.us/my.php?image=50620300ob5.jpg
Artikel:Hifonics Warrior HCX6.2C
Preis:60€
Standort:96049
Zustand:Gebraucht sonst keine Mängel.
Hifonics HCX 6.2C
16,5 cm 2-Wege-System
100 Watt RMS /200 Watt max., 4 Ohm
25 mm Gewebe Neodym-Hochtöner
12dB Frequenzweiche mit Pegeleinstellung
Einbautiefe 76 mm, Einbauöffnung 144 mm
http://img410.imageshack.us/my.php?image=50620314oz8.jpg
Artikel:Golf 3 Reserverad Gehäuse aus GFK
Preis:70€
Standort:96049
Zustand:Siehe Bild
5KG Harz mit 7KG Glasfasermatten laminiert.
ausenherum 10cm Holzrahmen.
http://img98.imageshack.us/my.php?image=50620325ou5.jpg
http://img134.imageshack.us/my.php?image=50620328db7.jpg
Alle Sachen zum verschicken oder abhohlen.
Würde auch tauschen.Am Preis kann man auch noch was machen.
MFG
[Beitrag von Heady87 am 06. Okt 2008, 05:36 bearbeitet]
DYNABLASTER
#2 erstellt: 06. Okt 2008, 05:19
Leute die Cerwin Vega hat Robert Zeff persoenlich gebaut, und so ist es eine maskierte Zapco! klingt luftig, sauber und klar! kaufeeeeeeen!
[Beitrag von DYNABLASTER am 06. Okt 2008, 05:20 bearbeitet]
Heady87
#3 erstellt: 09. Okt 2008, 18:08
Noch alles da.....
Verkaufe auch noch:
Impulse SD 800
Cerwin Vega 12.2
Preise lassen sich ausmachen.
MFG
[Beitrag von Heady87 am 09. Okt 2008, 18:10 bearbeitet]
Heady87
#4 erstellt: 11. Okt 2008, 17:56
Keiner interesse?
2x Cerwin Vega Vega 124
polosoundz am 02.07.2005  –  Letzte Antwort am 04.07.2005  –  5 Beiträge
Cerwin Vega Stroker SPL122
stebbe22 am 23.12.2005  –  Letzte Antwort am 02.01.2006  –  5 Beiträge
Cerwin-Vega V-MAX15.4
LeckaLutschi am 16.10.2007  –  Letzte Antwort am 21.10.2007  –  2 Beiträge
Cerwin-Vega XL-600.1
minki42 am 10.11.2007  –  Letzte Antwort am 22.11.2007  –  3 Beiträge
Cerwin Vega HED 12.2
Alpine*Alex am 02.12.2008  –  Letzte Antwort am 09.12.2008  –  6 Beiträge
Verkaufe Cerwin Vega Stroker mit Gehäuse
Prof.66 am 03.08.2005  –  Letzte Antwort am 16.09.2005  –  19 Beiträge
Hifonics Warrior,GFK Mulde
Heady87 am 09.01.2009  –  Letzte Antwort am 16.01.2009  –  8 Beiträge
Hawker C11, Cerwin Vega Vega 154
polosoundz am 21.08.2005  –  Letzte Antwort am 23.10.2005  –  30 Beiträge
Cerwin Vega STROKER 15 D
lanzpanz am 20.11.2004  –  Letzte Antwort am 03.09.2006  –  9 Beiträge
Zwei Cerwin Vega Sroker 12
Wuman am 15.06.2005  –  Letzte Antwort am 15.06.2005  –  3 Beiträge
  • Registrierte Mitglieder930.546 ( Heute: 1 )
  • Neuestes Mitglieday.
  • Gesamtzahl an Themen1.563.151
  • Gesamtzahl an Beiträgen21.817.836
