Oldscool-Amps mit POWER
Simon
#1 erstellt: 22. Mrz 2008, 13:15
Hi!
Jetzt stehen meine Oldscool Amps zum Verkauf.
Audison VR209
Artikelbeschreibung:
Die Leistung ist mit 2 x 110 Watt an 4 Ohm, 2 x 200 Watt an 2 Ohm und 1 x 400 Watt an 4 Ohm angegeben.
Sie ist sogar laut Hersteller und Bedienungsanleitung 1 Ohm stabil. Allerdings macht es kaum Sinn, da nicht viel mehr Leistung herausgekitzelt wird.
CHARACTERISTICS
AUDISON, has concentrated all of its know-how on the VR series of amplifiers rendering them as technologically advanced as can be made available today. Every aspect has been extensively attended to and resolved in the best possible way, not only through innovative solutions, but also by using high quality componentry, paying meticulous attention to detail, and providing accessory functions to maximize practicality. The PMW regulated type power supply uses MOSFET transistors which allow a remarkable power capability which doesn't diminish when battery voltage drops. A second separate voltage, stabilized and appropriately filtered, feeds the preamplification stages allowing an elevated overall rendering for better heat dissipation capabilities and to eliminate the classic disturbances generated by the power supply. The specularly separated PRE stages and a special lay-out permit high disturbance rejection and a considerable improvement in common mode rejection. The final stage's input employs a
complementary pair of constant current differential transistors polarized by LEDs with clearly advantageous results in terms of stability and tonal neutratity. The CASCODE voltage driver is appropriately treated in order to take complete advantage of the superior dynamics of this
configuration. The power stage is made up of a PURE COMPLEMENTARY SYMETRIC TRIPLET for maximum current linearization, and final stage transistors able to handle currents considerably higher than those normally required. Total feedback level under 10 dB, the adoption of some
local feedback, and a DC SERVO circuit allow for elimination of crossover distortion at low power and the right balance of THD and TIM distortion at high power. So ample driving possibilities are assured which can handle even the most difficult loads. In fact, the undistorted output power follows a nearly linear path up to loads of one Ohm. Because of these features your VR amplifier
can only provide you with the very finest in listening enjoyment.
Abmessungen: 256 x 290 x 57 mm
Artikelzustand:
Technisch in einwandfreiem Zustand.
Bedienungsanleitung gibts natürlich dazu.
Nur mehr für verdeckten Verbau einsetzbar.
Wurde von einem Laien schwarz lackiert und sieht wirklich nicht besonders aus
Zudem fehlt die Abdeckleiste.
Lanzar OptiDrive 500 TMS
Die Leistung ist mit 2 x 250 Watt an 4 Ohm, 2 x 500 Watt an 2 Ohm und 1 x 1000 Watt an 4 Ohm angegeben.
HOW TMS OPERATES
First it isolates the amplifier from all noise sources (RF, EMI, power tripple an ground noises).
Then it regulates the power supply voltages independently to all stages of the amplifier for more accurate and great stability.
Next it monitors the output load impedance and proctects in the event of a short circuit.
And last but not least it monitors for any prolonged temperature rises due to stress from low input voltage, hard clipping or low load impedances. It then re-distributes it´s resources to continue operating correctly and safely even under duress
This combindes systemwide intelligence is calles TMS (Tracking Management System) and allows the amplifier to defend itself from external hostile conditions. It of course still has all the normal protection circuitry an full sound capabilities that have built the reputation for Opti Drive amplifiers. The new system further enhances the amplifier´s operation by adding silent on - off operation and an additional 6 dB improvement in ground floor noise, all for a much more refined an pleasant listening experience.
Abmessungen: 229 x 489 x 60 mm
Artikelzustand:
Technisch perfekt.
Wurde erst kürzlich komplett überholt. (sieht man auch auf den Bildern.)
Optisch auch ein Hingucker. Handpoliert macht sie schon ganz schön was her.
Ein paar kleinere Kratzer sind bei dem Alter allerdings nicht vermeidbar.
Die originale Bedienungsanleitung liegt bei.
Hifonics Son of Colossus Gen. X
Die Gen. X sind die letzten Verstärker, die noch von Steven Mantz entwickelt und in den USA von ZED-Audio gebaut wurden.
Die Son of Colossus ist im Gegensatz zu den Collis ein Monoblock.
Die Leistung ist mit 600 Watt an 4 Ohm und 1100 Watt an 2 Ohm angegeben
1 Ohm macht sie laut vielen Aussagen unter ordentlicher Stromversorgung auch problemlos mit.
Abmessungen: 265 x 525 x 76 mm
Artikelzustand:
Sowohl technisch als auch optisch (bis auf minimalste Spuren) einwandfrei.
Bedienungsanleitung und original Verpackung gibts gratis dazu.
Preise:
Audison: 160€
Lanzar: 330€
Hifonics: 330€
Standort:
A-2202 Königsbrunn
oder auch im Norden Wiens
und freundlich grüßt
der Simon
Simon
#2 erstellt: 28. Mrz 2008, 11:27
Hi!
Über 200 Aufrufe und keiner zeigt Interesse?
Woran liegts?
der Simon
DyXe
#3 erstellt: 28. Mrz 2008, 11:53
Wie isn die Lanzar endstufe so? besser wie ne Eton pa 2802???
Simon
#4 erstellt: 28. Mrz 2008, 12:03
Hi!
Kann ich dir leider nicht wirklich sagen.
Hab nämlich nur die 1054 gehört.
Vom Klang her hat mir die Lanzar aber deutlich besser gefallen.
Bei der Leistung könnte die Eton ein paar Watt mehr haben. Glaub aber kaum, dass man das hören kann.
der Simon
DyXe
#5 erstellt: 28. Mrz 2008, 12:31
ist der preis vhb?
Simon
#6 erstellt: 28. Mrz 2008, 12:34
Hi!
An und für sich sind die Preise fix.
Aber eine Kleinigkeit lässt sich vielleicht noch machen.
der Simon
saikoo
#7 erstellt: 28. Mrz 2008, 18:21
saugute stufen!
nur meine taschen sind ein wenig leer.. :-P
vor allem die colli und die lanzar sind echt lecker!!!
Simon
#8 erstellt: 09. Apr 2008, 06:56
Hi!
saikoo schrieb:
saugute stufen!
Trifft es wohl genau.
So ein bissl Geld lässt sich doch immer auftreiben oder?
der Simon
Simon
#9 erstellt: 14. Apr 2008, 10:04
Hi!
Dann halt nicht.
der Simon
Audison VR 209 mit Zubehör und Kabel
KaratM90 am 22.11.2006  –  Letzte Antwort am 04.12.2006  –  2 Beiträge
Biete 2 neuwertige RE Audio SX 15
Deesazta am 15.06.2007  –  Letzte Antwort am 29.06.2007  –  15 Beiträge
Verkaufe Velocity VR250
W.I.S.S.I am 02.09.2007  –  Letzte Antwort am 09.09.2007  –  2 Beiträge
Hertz ESK 165
Wallo18 am 10.09.2008  –  Letzte Antwort am 15.09.2008  –  2 Beiträge
2 x Spinner Audio M10
DDStocki am 28.07.2011  –  Letzte Antwort am 05.09.2011  –  3 Beiträge
SPL Dynamics EXT 2000D
hansonXschrempf am 19.03.2007  –  Letzte Antwort am 01.04.2007  –  4 Beiträge
us amps 400
julian122345 am 29.07.2007  –  Letzte Antwort am 06.08.2007  –  20 Beiträge
Amps (Steg K2.01, Steg QM105.4, Rodek R480i)
da-muddi am 16.02.2013  –  Letzte Antwort am 22.03.2013  –  3 Beiträge
[ BIETE ] Endstufen und 2 Subwoofer
kaiserkoehler am 12.08.2007  –  Letzte Antwort am 02.09.2007  –  4 Beiträge
Verkaufe Eton PA 502
Callipo am 29.10.2006  –  Letzte Antwort am 31.10.2006  –  8 Beiträge
  • Gesamtzahl an Beiträgen21.839.249
