HIFI-FORUM » English » Other hifi (Engl.) » TUBES | |
TUBES+A -A |
Amp_Nut
#51 erstellt: 26. Dez 2008, 20:03 | |||
A couple of 'reminders' for commercial products that are widely retailed : 1. The expensive MOST 'component' in an integrated amp or a Pre amp or power amplifier is the ...... Nope ! Not the Transformer, or the tubes but the chasis ! 2. All the Electronic components PUT TOGETHER, will cost 10% of the MRP ! 3. The MRP provides between a 70% to 50% margin on the MRP. 4. At 30% to 50% of MRP, the manufacturer not only bears all the component costs, development and manufacturing cost, but also most of the advertising cost. So you dear customer, get little for the price you pay. In sharp contrast, a DIY ...... [Beitrag von Amp_Nut am 26. Dez 2008, 20:05 bearbeitet] |
Manek
#52 erstellt: 27. Dez 2008, 18:12 | |||
Ampnut Good point. One sometimes tends to forget that the chasis work costs quite a bit which in cases like the cdp also translates into better sonics if implemented right Many advantages to a good strong well designed chasis for amps as well. Many people do take the chasis for granted and may not put much weight when judging equipment prices Manek |
Manek
#53 erstellt: 27. Dez 2008, 18:16 | |||
A question for u tube guru's again..... What would your selection criteria be for a tube rectifier in the various types of tube amps ? Manek |
viren
#54 erstellt: 28. Dez 2008, 05:06 | |||
Hi Sure, that's been the bane of high end audio - over engineering, especially the chassis. You can make it as heavy and flashy and expensive as you want. It makes for good photographs and marketing brochures and equipment prices. Beyond a point, it serves no purpose to the music. I've seen enough high end gear where the circuitry, and components, were pathetic for the price. Outside, it looked gorgeous! Manek, The largest common valve rectifiers can put out 250mA DC. For less current, there are numerous valve rectifiers available. You can't run them at maximum, because you need some headroom for current swings. So, if your circuit demand is within that, do use them. They provide another level of warmth and detail to music. Viren |
sivat
#55 erstellt: 28. Dez 2008, 06:52 | |||
high permiability of good core, enables you to achive good level of inductance with lower number of coil windings, hence giving a lot of advantages...like lower coil resistance and capacitance, etc., |
sivat
#56 erstellt: 28. Dez 2008, 06:56 | |||
Chassis are expensive, not necessarily for the looks, but for the required mechanial isolation. This does affects the sound. Good well built chassis are significantly "more" expensive for DIY'ers, because of lower Qty !!. The DIY'er in India do have thier advantage with thier friendly neighbourhood workshop...but still more expensive than making 1000 pieces of the same chassis. Chassis is not just important for CDP, but also for all electornics, expecically a power amp. |
sivat
#57 erstellt: 28. Dez 2008, 07:01 | |||
I'm not tube guru and hence the Q is not for me...but i still thought i will share my experience. I feel, tubes in a PSU (on B+) makes the sound...called famously "tubey". I 've tried different tubes. For a more linear sound, the solid state diodes do hold thier advantages. There are many many choices available, but u need to buy them from abroad...or thru RS component. Schottky diodes are a must for filament PSU and if possible for B+ as well !!. These is expensive though !! |
Manek
#58 erstellt: 28. Dez 2008, 07:43 | |||
Viren...let me try and explain.....maybe I didn't explain better earlier... Besides the current draw...why would you use one rectifier tube over another, given that both allow for the swings in a circuit ? Have you managed to attribute certain audio qualities to certain rectifier tubes ? Secondly would you use a certain tube rectifier with certain preamp tubes based on audio characteristics ? We have seen that tube rectifiers do make a difference in the sound quality and characteristics hence the question. Siva, yes I know you prefer the ss diodes. My other pre has solid state rectification and upgraded fast diodes and both have 6sn7's. But I do love the option of tweaking virens amp given the choice that I can swap out the rectifier and make sets of output tube + rectifier that gels best with each other. Manek |
Manek
#59 erstellt: 07. Jan 2009, 10:12 | |||
Viren I found that when one puts 4 solid aluminium pieces under/instead of the rubber feet of the lyrita preamp, the difference is very palpable in the reproduction of cymbals, chokes, brushes and the tom tom drums. What I did was put 4 large circular volume control knobs made of aluminium under the rubber feet. You should try it if you haven't already that is :-). All of rs 160 only. Looking to replace them with brass but that will take some searching.....no I won't go with the very expensive tip-toes just yet :-) Manek |
viren
#60 erstellt: 10. Jan 2009, 14:51 | |||
Hi Manek, Damping vibrations to and from components is again a very subjective thing. It is so dependent on the setup, that there are almost no rules, and its all by trial. The nature of your rack, the shelf the component sits on, the sound intensity in that corner, all play a part. I'm sure you heard what you did - play around with what sounds best. The same holds while changing rectifier valves. As long as they are somewhat equivalent (check pinout!), you can substitute them, and they definitely sound different. Play around with what sounds best to you. And, my experience is different from Siva's. I feel valve rectifiers, over ss diodes, take the valve amp to richer level of tonality. Viren |
viren
#61 erstellt: 10. Jan 2009, 15:03 | |||
Hi, Amp Nut's comment: "The expensive MOST 'component' in an integrated amp or a Pre amp or power amplifier is the ...... Nope ! Not the Transformer, or the tubes but the chasis !" got me curious as to my 2A3 SET amp. No doubt my valve amps are very iron hungry, and here's the tally: Lyrita 2A3 SET, iron to chassis ratio 2.8 Viren |
sivat
#62 erstellt: 10. Jan 2009, 18:01 | |||
That's exactly why i avoid tubes in PSU |
Amp_Nut
#63 erstellt: 10. Jan 2009, 18:50 | |||
Viren said:
Congrats ! Viren. As an audiophile I salute you I guess your focus away from the chasis would have cost you sales ? I recall my talk with (probably ? ) the most sucessful AV retailer in the country ( and an ACE Pair of Ears ) ... he said that though he loves interacting with Audiophiles, they ( we ! ) analyse the matters to death, and rarely buy. I guess that Audiophiles are like Film critics. Its Great to have their approval, but it rarely puts food on the table.... Power to you, Viren for bringing GREAT audio quality at a Very Reasonable ( Throwaway by audio standards ) I recently heard your Rs 15,000 Pre Amp and I was Very Appreciative of what you offer for Rs 15K. [Beitrag von Amp_Nut am 10. Jan 2009, 19:02 bearbeitet] |
Manek
#64 erstellt: 10. Jan 2009, 20:41 | |||
Viren Hi. About damping vibrations and resonances....I observed the same behavior with my other setup. It tamed my bass boom by 70 percent ! So the same effect in two setups completely different and spread across two different cities ! So maybe I have stumbled upon some cheap yet effective dampers. Mind you it works best in combination with the stock rubber feet. Using them directly on the chasis works to about 80 percent of what it would with the rubber feet. So maybe I am thinking that just one material may not do the trick all the time but a combination of damping materials would be better to work with different types of resonances. Anyone know of a more scientic way of guaging the various resonances in the equipment we use ? Rather than just trial and error ? Manek |
aks07
#65 erstellt: 13. Jan 2009, 08:51 | |||
Trial and error is the most scientific way when tubes are involded. Off track, but so much tubes discusssion makes me melancholy How about starting another "last one" tube amp project? Anything to beat the recession blues. |
Manek
#66 erstellt: 13. Jan 2009, 19:37 | |||
Aks What did ypu have in mind ? Manek |
aks07
#67 erstellt: 13. Jan 2009, 22:30 | |||
How about a SET amp? Throw up some ideas. |
Amp_Nut
#68 erstellt: 14. Jan 2009, 05:14 | |||
How about a Solid State SET Transformer coupled amplifier ? Can be made Very Cheap and quick. Had made one in my college days... that was ofcourse a "romantic era" for my Audio days. Sounded Great ( Then ) If I am not mistaken, the Rethym speakers were demoed at the Hyatt show in Mumbai ( approx 5 years ago ) with a 10 Watt Transformer coupled Solid State Amp. Prithvi, is that correct ? ( SORRY ! I know .... this is a TUBE Thread! ) |
Manek
#69 erstellt: 14. Jan 2009, 07:23 | |||
Any other brands doing that besides rethm ? Aks how about the tubes you mentioned on this thread ? The ones you wanted to use ? Manek |
aks07
#70 erstellt: 14. Jan 2009, 08:18 | |||
If it is a SET, then esteemed forum members like Shri Viren and Shri Sivat have explored the both the ends of the power range. Viren ji with 2A3 and Sivat-ji with 845 SET. Why not something mid power? Like a 300B SET in the 8~10 WPC range? |
Manek
#71 erstellt: 14. Jan 2009, 12:10 | |||
Hmmm..... 10 watts is pretty decent to begin with. You have my vote. Manek |
aks07
#72 erstellt: 14. Jan 2009, 12:44 | |||
About 9 WPC shoul be a good compromise keeping in view the harmonic distortion and conserving tube life. Do you think this warrants a new thread out in the DIY section? |
viren
#73 erstellt: 14. Jan 2009, 16:37 | |||
Hi aks, Go for it! in DIY! Viren |
aks07
#74 erstellt: 14. Jan 2009, 17:45 | |||
Manek
#75 erstellt: 16. Jan 2009, 06:37 | |||
Viren I did get my hands on 4 brass conical cabinet handles with flat bases :-) What can I say, they do a shade better than the aluminum circular knobs :-) Sasta, kifaayti, tikaaoo tweak. Manek |
Arj
#76 erstellt: 16. Jan 2009, 08:03 | |||
Fantastic Sir ! this is the true spirit of tweaking. do try to put a dab of blutqac either at the component level or at the surface to rprevent any vibration ! |
Manek
#77 erstellt: 16. Jan 2009, 13:51 | |||
Tks arj Now to do the same with the source and hear the difference. Once we finish the feet, then we shall do the blu tac thingie to the source first and then the pre. Manek |
Arj
#78 erstellt: 17. Jan 2009, 15:16 | |||
Just replaced the stock Sovtek 6l6GCs in my amp with Svetlana SED 6L6GCs. what a change in sound ! the hardness and edge in the midrange/treble has just gone away.. . My first experience with Tube rolling and its been fantastic ! |
Manek
#79 erstellt: 18. Jan 2009, 06:30 | |||
Welcome to the club. Enjoy yr tubes. You have now been officially bitten by the bug ! Keep the sovteks as a spare set. Yes good tubes do make a lot of difference. These are current production right ? Arj, now you should go for a good set of matched NOS if you can after a few months. Those should take your amp a notch higher. Be careful about the source of the tubes. Manek |
Arj
#80 erstellt: 18. Jan 2009, 09:20 | |||
Manek, the advise on the Sovteksas a backup is practical and wise ! I have been trying to ask around about the 6L6/KT66 family. as per what i cold learn , this is one family where most of the good ones available are as good as NOS apparently . The leben does have the option of using EL34s as well..any favourites/ recomendations on those ? think i have the source/amp/speaker thing sorted out by now and really need to focus on the room now..and the software as well any innovative ways of storing CDs ? does anyone store them by removing them from the Jewel cases and using alternative storage ? [Beitrag von Arj am 18. Jan 2009, 09:21 bearbeitet] |
Manek
#81 erstellt: 18. Jan 2009, 10:56 | |||
Arj sir....pardon my going on about this but if your amp has preamp tubes, those would now be up for the same switch if you haven't upgraded them yet :-) On el34's, mullards, amperex, telefunken, ei(maybe) Groove have good sounding el34's I am told out of the present lot. The svetlana and jj should have decent sounding ones too. On cd storage I am myself looking for alternative means but I doubt if I want to get rid of jewel cases. There are electro mechanical libraries available which store cds and bring them out once you click on the index like a jubebox. This one won't do for me. Hey ! Hold on a minute ! How about an audiophile quality jukebox ? :-) hee hee, sorry arj but I'm just trying to humour myself, have a nasty cold and have been quite cranky since morning. Manek |
Arj
#82 erstellt: 18. Jan 2009, 18:40 | |||
The amp comes with a Quad of NOS Sylvania 6CS7. what i was told was that the impact of changing this is very subtle, unlike the power tubes. might be on the lookout for a Tung Sol or a GE at some point
well the best audiophile Jukebox is a digital HDD source you just need to rip them ! i have bee thinking of looking for some sort of wall hanging storage that uses Sleeves in which the covers and Liners could also be included. |
Manek
#83 erstellt: 18. Jan 2009, 18:48 | |||
Arj
#84 erstellt: 19. Jan 2009, 07:26 | |||
Thanks manek, this is a nice link with lots of good info ! |
stevieboy
#85 erstellt: 19. Jan 2009, 08:13 | |||
welcome to the gang arj! good to hear of another member enjoying tube rolling. yes you're right. changing the preamp tube would have a less discernable effect than the power tubes. changing the rectifier tube in my amp made a BIG difference. i wouldn't say better just different. so depending on my mood i can use the gz34 or the 5y4G. the 5y4g is more spaced out, relaxed. the gz34 is more compact punchier sounding. fav is the 5y4g though. do you have rectifier tubes in your amp? |
Arj
#86 erstellt: 19. Jan 2009, 08:59 | |||
Hey stevieboy. I seriously dont want to get into tube rolling..it is scarier than cable swaps wince the changes are not as subtle ( ) From what I could understand, the Lebens rectification is via Diodes,not tube rectified. Apparently this was to avoid any Euphony in the sound .There is a 6CJ3 "Dumper tube" to avoid sudden loads on the Output tubes..not sure if changing that has any impact since it is not really rectifying , but only "loading" the main output in order to prolong the life.? |
sivat
#87 erstellt: 19. Jan 2009, 09:49 | |||
The tube vendor in SJP road called me last week ...and told me that he had some KT88 ...@ Rs.2k per piece. His tubes are not very reliable...mostly military junk. Incase any of you might be intrested....walk along SJP road...u will find the shop with tubes displayed. |
stevieboy
#88 erstellt: 19. Jan 2009, 10:43 | |||
thanks for the tip siva! will take a walk on the tube side one free weekend! arj, yeah experienced the same not so obvious changes in my input tubes. had two pairs in my previous amp but no noteworthy changes (at least changes i could notice and appreciate). viren did warn me there'd be hardly any change but being my first tube amp i just had to see and have fun. rectifier tube swap was a whole different ballgame. research 'the' power tube to have and start saving hehe. havent yet tried a 2A3 change since the better single plate alternatives will cost as much as my amp itself!!! |
Arj
#89 erstellt: 19. Jan 2009, 10:53 | |||
I did just that..got in touch wih multiple folks using the amp before zeroing down on this one:) the best next upgrade is a Western Electric 350Bs..think that costs $1000+ have another option of using Golden Lion KT77s as well. but let me wait for the itch to try it get real bad ! |
Manek
#90 erstellt: 19. Jan 2009, 19:45 | |||
Good thinking arj Time like these are not too conducive to large scale experimentation. Manek |
stevieboy
#91 erstellt: 20. Jan 2009, 08:11 | |||
on the contrary manek, times like these are perfect for those grand dreams keeps you going you know what i mean? arj ah that's the ultimate biggie i wanted to know. all tube amps have one utterly unaffordble or out of reach or save-up-for-many-years tube will check out the we 350Bs. maybe i'll invite myself over one day to listen to your amp and speakers? |
Arj
#92 erstellt: 20. Jan 2009, 10:39 | |||
Anytime Dude ! please bring some music also over. YOu can also help me in evaluating my HDD based sound [Beitrag von Arj am 20. Jan 2009, 11:01 bearbeitet] |
stevieboy
#93 erstellt: 20. Jan 2009, 11:54 | |||
HDD??? you've moved beyond the reimyo? ok maybe we can discuss this when i do drop in or it'll go off topic. |
Arj
#94 erstellt: 20. Jan 2009, 12:35 | |||
no no..have a PC connected to the reimyo |
Manek
#95 erstellt: 31. Jan 2009, 09:03 | |||
guys jj the tube manufacturer has started to make valve amps too under its name.....anyone heard them ? manek. |
Arj
#96 erstellt: 10. Aug 2009, 07:34 | |||
Would be grateful if someone could point me to any specific shop selling tubes at SP road ? looking specifically for a nice Quad of KT66/KT77/KT88 OR some nice 6CJ3 or 6CM3. |
Savyasaachi
#97 erstellt: 10. Aug 2009, 09:14 | |||
No mention of the 6CG7/6FQ7 family? isn't anyone running these tubes? |
Manek
#98 erstellt: 15. Aug 2009, 06:03 | |||
Arj Be3 amplifiers in vashi near mumbai could help you. I remember him telling me he was going to sell current prod sets. Plus he also has a tube tester on which he can test them. Manek |
Manek
#99 erstellt: 15. Aug 2009, 06:07 | |||
Sachi I doubt anyone is running these. Just two possibilities though, viren or aks may have played around with them. Manek |
Arj
#100 erstellt: 15. Aug 2009, 06:50 | |||
Hey manek, i havce sourced some from Mohammad of Be3, wanted some cheap local tubes to try out..thats all |
Manek
#101 erstellt: 15. Aug 2009, 12:05 | |||
Yep Gotcha.....but has he started selling current prod stuff ? I wonder if ebay india has a sweet deal or two ? I wish someone would start to sell current prod models at reasonable prices, or is there one already ? Even the EH line of tubes here cost an arm and a leg or atleast that was the case earlier. the only valve amp maker/retailer I know of who also keeps a nice alternative or two for his equipment is viren. Manek |
Be3 apmplifiers and Tube Testing Manek am 01.01.2009 – Letzte Antwort am 01.01.2009 – 2 Beiträge |
Need tubes Savyasaachi am 06.05.2009 – Letzte Antwort am 07.05.2009 – 5 Beiträge |
connecting the ipod anirvan am 11.07.2006 – Letzte Antwort am 16.08.2006 – 25 Beiträge |
tube sources in india Manek am 12.06.2008 – Letzte Antwort am 10.08.2008 – 11 Beiträge |
Multi room system with media server Manek am 18.04.2009 – Letzte Antwort am 20.04.2009 – 5 Beiträge |
Audio quality difference between DVD player and CD player sandipb am 16.11.2007 – Letzte Antwort am 17.11.2007 – 2 Beiträge |
Need suggestions for Tuner/CD system SUNILYO am 15.04.2008 – Letzte Antwort am 23.04.2008 – 21 Beiträge |
Rethms Saadhana wins 6 moons 2008 Blue Moon Award Prithvi am 02.01.2009 – Letzte Antwort am 02.01.2009 – 3 Beiträge |
Tube Buffers herculepirate am 28.07.2009 – Letzte Antwort am 30.07.2009 – 34 Beiträge |
DVD player power supplies Manek am 31.07.2006 – Letzte Antwort am 04.08.2006 – 14 Beiträge |
- Registrierte Mitglieder927.082 ( Heute: 2 )
- Neuestes MitgliedBrentbic
- Gesamtzahl an Themen1.554.753
- Gesamtzahl an Beiträgen21.620.895
